AG-HPG10 Portable P2 Gear Player/Recorder and Canon XLH1
COW Forums : Panasonic Cameras
Carlo Ferraro
on Sep 10, 2009 at 10:55:16 pm
Can someone tell me if it is possible to record from Canon XLH1 directly into the AG-HPG10 Portable P2 Gear Player/Recorder by Firewire or SDI ?
Jeremy Garchow
Re: AG-HPG10 Portable P2 Gear Player/Recorder and Canon XLH1
on Sep 10, 2009 at 11:09:58 pm
Sdi for sure, but probably not FireWire.
Carlo Ferraro
on Sep 10, 2009 at 11:23:06 pm
Jeremy:
My question is more towards the codec since the output of the camera is 1440x1080, 1080i.
Jeremy Garchow
on Sep 11, 2009 at 1:24:40 am
That's the tapeless version. Coming out of the SDI Is ucomprssed video. With that recorder you can capture to full raster 10bit AVC-I mxf files. Much better than the hdv of the canon.
Jan Crittenden Livingston
on Sep 11, 2009 at 3:34:13 pm
The AG-HPG10 only has 1394 as an input and so it is looking for a compatible codec to come in on a compressed domain. This means that only the DV codec generated by the GH1 is compatible. However, since the AG-HPG20 has an HD-SDI in, it could be used to record into DVCPRO-HD or AVC-Intra fro the HD-SDI out put from the GH1.
I hope this helps,
Jan
Product Manager, HPX500, HPX300, HPX170, HVX200A
Panasonic Broadcast & TV Systems
Jeremy Garchow
on Sep 11, 2009 at 3:35:37 pm
Woops, sorrry about that. I meant the HPG20.
Jeremy
