HVX Output HD and SD signal at the same at????
COW Forums : Panasonic Cameras
Paulo Uchoa
on Sep 1, 2009 at 8:59:26 pm
So I need to output from the HVX both 1080i Component signal and 480i Composite at the same time, how do I do this? From what I understand the camera can only output either one or the other but not both, so is there an adapter out there, that can do this simple task?
-Paulo
Michael Sacci
Re: HVX Output HD and SD signal at the same at????
on Sep 2, 2009 at 4:12:00 am
I'm almost positive that the composite and Y/C ports are always active and of course are always SD, so when the composite is set to HD you should have watch you are wanting.
Do you have a camera, this would be quick thing to test.
Paulo Uchoa
on Sep 2, 2009 at 5:47:08 am
When you have the component plugged in, the composite stops working.
-Paulo
Shane Ross
on Sep 2, 2009 at 8:47:11 am
You can't do both. Sorry.
Shane
Michael Sacci
on Sep 2, 2009 at 3:54:17 pm
I thought I used both at one time, maybe it was the composite and the Y/C, so much for my memory.
Paulo Uchoa
on Sep 2, 2009 at 6:31:44 pm
I understand that you can't do both. My question is, is there an adapter that can convert 1080i Component to 480i Composite?
-Paulo
David Williams
on Oct 3, 2009 at 3:41:47 pm
Redbyte Decimator
