24PN vs 30PN
COW Forums : Panasonic Cameras
Cory Travalena
24PN vs 30PN
on Aug 27, 2009 at 4:53:48 pm
I have a question, and nobody can seem to give me an answer. I have a Panasonic HVX200. When I shoot 24PN, the time on the cards nearly doubles. I know the reason for that, is because it is recording without the pulldown, so it is getting rid of the additional frames. What confuses me, is why then if I shoot 30PN, I get the same amount of storage as if I am shooting 24PN? It has no frames to remove. So confused.
CT
Steve Eisen
Re: 24PN vs 30PN
on Aug 27, 2009 at 6:41:15 pm
Let me confuse you more. There is no removal of frames in PN mode. When you shoot 24pn, it records exactly 24 frames. When you shoot 30pn, it shoots exactly 30 frames. PN (native frames) only records frames needed.
24 pn = 42 minutes 16 gb card.
30 pn = 34 minutes 16 gb card.
No need to be confused. P2 cards takes the worry out of pulldown (removal of frames).
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group
Robert Ober
Re: 24PN vs 30PN
on Aug 29, 2009 at 10:53:36 pm
[Steve Eisen] "There is no removal of frames in PN mode"
Actually, according the the HPX300 manual it removes them internally before writing to the card. So they can use the same some of the same circuitry as cams that don't do PN.
Robert
Adam Smith
Re: 24PN vs 30PN
on Aug 28, 2009 at 5:12:31 am
The 720p standard is 60 progressive frames, so you should see around double the run time when shooting 30pN and more than double with 24pN.
Right now on my HPX500 I have:
43 mins available at 720/24p or 720/30p or 720/60p
84 mins at 720/30pN
104 mins at 720/24pN
-Adam
Video Photographer / Avid & Final Cut Editor
