Sync Sound Problem
COW Forums : Panasonic Cameras
Zach Kuperstein
Sync Sound Problem
on Aug 12, 2009 at 4:21:44 pm
I've shot 720p/24pn footage and recorded audio with an external Tascam recording device at 16bit/48khz. I then try to sync the footage with the audio in FCP using a clapped slate and aside from the clap itself, they are not even close.
I've read forums saying that the sequence settings must match the audio bitrate and they do.
I should note that the audio is a .wav file if that makes a difference.
Any thoughts on why my sound won't sync up? Any suggestions on what I might try to fix it?
Greg Nosaty
Re: Sync Sound Problem
on Aug 14, 2009 at 3:51:09 pm
That is strange. Are they Bwave files (broadcast wav)? You could try converting one clip to an AIFF 16bit/48Khz in iTunes and see if that makes a difference.
I've had some issues with sync when exporting OMF files for my audio post guys so maybe there is some glitch with FCP.
cheers,
Greg Nosaty
Cinemontage Productions Inc
