audio clicking problem with P2 imports
COW Forums : Panasonic Cameras
walter schlomann
on Jul 16, 2009 at 5:24:59 pm
Using a lap top and final cut log and transfer, and viewing 720p material in the log and capture preview all is fine. After final cut makes quicktimes, these new .mov files have a clicking sound throughout. Any thoughts? ANy way to control the parameters of these new .mov files? We also shot a bunch of material on 720pn and there is no problem with these files.
Jeremy Garchow
Re: audio clicking problem with P2 imports
on Jul 16, 2009 at 6:58:22 pm
Check out the audio waveforms, do you see the clicks there? Have you turned off ch3 & 4 if you aren't using them?
walter schlomann
on Jul 16, 2009 at 8:37:09 pm
Hi Jeremy,
Thanks - i think we figured it out. When importing 720pn there's no need to worry about the duplicate frames option, and so we've never 'unchecked' the box. I guess with 720p it does indeed matter - by unchecking the box the sync and clicking problems go away.
Walter
