HD monitor suggestions
COW Forums : Panasonic Cameras
Andrew Conner
on Jul 15, 2009 at 7:52:36 pm
I am looking to get a nice HD monitor for the field and office for my HPX 170. I would like it to be between 20 and 25 inches. Do you have any recommendations? What is the best way to hook the 170 up to an HD monitor? I see two outputs on the back of the camera. Will either of these allow me to preview it in true 720p or 1080p? And finally... will I need a special adapter for this?
Thank you! Any info is much appreciated.
John Fishback
Re: HD monitor suggestions
on Jul 15, 2009 at 9:54:34 pm
We have a Panasonic 17" High-Def monitor we use in the field. They have a larger monitor, but it would be more cumbersome to travel. Be sure to checkout Flanders Scientific monitors, too. Your camera has a HD-SDI out which you'd connect to your monitor. No adaptor necessary - just a SDI cable with BNCs on each end.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
