Playing QT Export from FCP on Macs without FCP installed
COW Forums : Panasonic Cameras
Steve Langmanis
on Jul 2, 2009 at 4:16:26 pm
Hi P2 users,
Could anyone enlighten me as to why is it that when I export a sequence (footage shot on Panasonic 200 & 500) straight from Final Cut Pro (6) as a Quicktime, the QT will not play on another Mac that doesn't have Final Cut installed. I have tried installing Quicktime Pro but all I get is audio and no visual. Do I need to add DVCPRO HD as a plug-in to Quicktime Pro?
Any nugget of knowledge appreciated.
Many thanks,
Steve
http://www.langmanis.com
Noah Kadner
Re: Playing QT Export from FCP on Macs without FCP installed
on Jul 2, 2009 at 5:04:25 pm
Export to ProRes. DVCPROHD is a licensed codec that only comes with FCP. It will not play on a PC nor an a Mac without FCP installed.
Noah
Writing RED: The Ultimate Guide to Using the Revolutionary Camera!. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Lens Adapter Guidebook, Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
http://www.callboxlive.com
Steve Langmanis
on Jul 2, 2009 at 7:14:25 pm
Hi Noah,
Thanks for the speedy reply. BTW I have your DVD on Color. Very useful!!
S.
John Fishback
on Jul 2, 2009 at 5:07:37 pm
You need the DVCPro HD codec that's installed by FCP. Calibrated has this solution.
http://www.calibratedsoftware.com/QDVCProHD.asp
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24" TV-Logic Monitor
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Tim Baker
on Jul 2, 2009 at 5:45:40 pm
I believe it would also depend on whether you are exporting as a self contained movie or a reference movie. If you are exporting as a reference...it will always look for the FCP timeline to "reference" what should playback in the QT.
If I am not mistaken...I usually just export reference movies to drop into DSP and other programs so I dont have these huge, uncompressed video files to deal with on my hard drives.
Tim Baker
Chameleon Mobile Video Productions
(239)849-3295
"It is not the light at the end of the tunnel that we should seek...it is the courage to take the next step in the dark that we must find."
Steve Langmanis
on Jul 2, 2009 at 7:25:36 pm
Hi Tim,
When exporting the RAW sequence I use Quicktime as a self-contained movie. I'm looking into a format / codec that Quicktime has as part of its standard installation. Maybe Apple Pro Res if its recommended.
Thanks again,
Steve
Steve Langmanis
on Jul 2, 2009 at 7:19:45 pm
Hi John,
Thanks for the link and info. Pricey solution especially for multiply machines.
I'm thinking now maybe its not such a good idea to be using DVCPRO HD as a Sequence Format preset.
Do you think I should use something like Apple ProRes 422 (HQ) 960x720 25p 48KHz in FCP when shooting on the Panasonic 200 & 500 at 720p in PN Format..?
Thanks again for any advice,
Steve
Michael Sacci
on Jul 3, 2009 at 1:06:35 am
Don't use (HQ) just standard ProRes will work. You will need to install the play only codec on each system, which is available for free for both Macs and PCs.
Steve Langmanis
on Jul 3, 2009 at 6:45:54 am
Hi Michael,
Many thanks for the reply and info!
Steve
Noah Kadner
on Jul 4, 2009 at 3:53:57 am
I'd still edit in DVCPROHD- nothing gained by making everything ProRes in the cut. But if you need to share outputs with multiple non-FCP systems definitely export to ProRes.
Noah
Steve Langmanis
on Jul 4, 2009 at 6:32:49 am
Thanks again, Noah.
I'll give this a go.
Steve
