Confused? | AJ-HPX2000, true 1080P
COW Forums : Panasonic Cameras
Daniel Elder
on Jun 30, 2009 at 9:01:07 pm
I have updated the HPX2000 with the newest firmware update, but I can't tell if it gets true 1080P, the setting I can get to is 1080 59.94i then has an advance pulldown to 24P, is this the only 1080P setting available, or is their something I'm missing? Also does adding the AVC-Intra board add true 1080P capabilites?
Thanks.
Dan
Daniel Elder
producer
http://www.luminair.com
Jeff Regan
Re: Confused? | AJ-HPX2000, true 1080P
on Jul 1, 2009 at 2:28:16 am
I'm not sure what "true 1080p" is, but the HPX2000 uses native 720p sensors and upscales to 1080. DVCPRO HD does not offer 1080/24P or 30P Native modes, however AVC Intra does offer 1080/24P and 30P Native. Regardless, the HD SDI output is whatever frame rate, progressive or interlace over 59.94i.
Jeff Regan
Shooting Star Video
http://www.ssv.com
gary adcock
on Jul 1, 2009 at 1:37:16 pm
[Jeff Regan] "I'm not sure what "true 1080p" is"
True "p" is just that a signal that is captured and played back as progressive only, no mainstream "video" cameras I know of output 1080 content as anything other than PsF.
1080 by SMPTE default is PsF and only very rarely ever true P on playback (Red and Phantom being the rare exception).
an explanation of PsF is here:
http://forums.creativecow.net/readpost/193/875880
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
Check out
http://www.aja.com/kiprotour/
Inside look at the IoHD
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Daniel Elder
on Jul 1, 2009 at 2:09:54 pm
Thanks for the answers Jeff & Gary, yeah I guess I was wondering if the 1080 59.94 to 24P is considered 1080P? or is that still 1080i on the HPX-2000?
Daniel Elder
producer
Jeff Regan
on Jul 1, 2009 at 3:46:35 pm
Using System Mode 1080/59.94i, recording in DVCPRO HD, 1080/24p will be 23.98p over 59.94i(2:3), no Native mode available for P2 recording. HD SDI output will be 23.98Psf over 59.94i(2:3). There is also a PA mode for a 2:3:3:2 pulldown.
Using System Mode 1080/23.98Psf recording in AVC Intra, 1080/23.98p will be 23.98p Native for P2 recording. HD SDI output will be 23.98Psf over 47.96i(2:2).
So the key is using AVC Intra 50 or 100 onto P2 cards to achieve full progressive capture, although many would argue that Psf is still progressive after the segmented fields are combined.
Maybe Jan Crittendon or Steve Cooperman from Panasonic can weigh in on this?
Jeff Regan
Shooting Star Video
http://www.ssv.com
Daniel Elder
on Jul 1, 2009 at 5:10:24 pm
To achieve the AVC Intra I would need to get the AJ-YBX200G board for the camera, correct?
So the 1080 59.94i to 24P or 24PA is achieving what we know as 1080P just through using segmenting the fields, thus removing any of the interlacing that might happen otherwise. The fields are progressive but it is removing any motion between the two segments that are interlaced, so we aren't as likely to see the interlacing that is going on.
So much information, but it's very interesting stuff. But at the end of the day, I want to upgrade my HPX-2000 to the AVC Intra board to achieve real progressive scanning vs. the PsF scanning?
Daniel Elder
producer
Jeff Regan
on Jul 1, 2009 at 7:22:38 pm
Daniel,
Your understanding is similar to what I believe to be the case. AVC Intra 100 offers a lot of benefits over DVCPRO HD, so that the cost of the option board should be worthwhile. I really like the fact that Native recording is available in 1080p now, besides the 10 bit, full raster image quality benefits.
I've used AVC Intra 100 with HPX3000's and HPM110 P2 Mobile, and it's a fantastic codec.
Jeff Regan
Shooting Star Video
http://www.ssv.com
Daniel Elder
on Jul 3, 2009 at 3:28:22 pm
Great to know, we'll be purchasing that upgrade. Thanks for the insight everyone
Daniel Elder
producer
