Recording using Letus
COW Forums : Panasonic Cameras
Rick Osborne
on Jun 19, 2009 at 8:03:52 pm
I've done some recordings with my panasonic with the Letus adapter and noticed that the picture is a little grainy. I was wondering if I should film in the Video Mode on the Camera or use the Film Mode which I've been using. I turned the scene file off. I just think the Letus adapter and the Film mode are competing to give me the film look. Hint- Too much of a good thing.
Rick
Jason Jenkins
Re: Recording using Letus
on Jun 19, 2009 at 10:01:50 pm
Which Letus are you using? What was the fstop of your taking lens?
Jason Jenkins
Flowmotion Media
Video production... with style!
Rick Osborne
on Jun 20, 2009 at 2:48:08 am
I am using the Letus Extreme. I am not really sure of the fstop settings. I've taped indoors and out, with the same effect.
Rick
Jason Jenkins
on Jun 20, 2009 at 4:48:05 pm
First, make sure the Letus is turned on :) I've found that I can't stop down past f4 on the taking lens without seeing the grain of the ground glass. That could be your issue.
Jason Jenkins
Flowmotion Media
Rick Osborne
on Jun 21, 2009 at 3:18:51 pm
Jason,
I've noticed you can definitely tell when the Letus is not on. I'll try to keep my stops above f4 and see if that works.
Buck Kahler
on Jun 30, 2009 at 11:01:11 am
I've noticed that I see the grain quite a bit when my scene is too bright and I try stopping down on the HVX. Keep the lens wide open and make your adjustments on the HVX. I find that if you're trying to stop down below f4, you probably need to put on some ND. If the ND on the HVX is too much, look for some cheap ND for the lens itself.
-Buck
