Multiple ShotPut Pro running at the same time
COW Forums : Panasonic Cameras
Matthew Romanis
on Jun 10, 2009 at 9:53:11 am
Hello all,
Can any of the file handling programs such as Shot Put, handle multiple cards at once?
Can I use a PCD 25/35 loaded with 5 cards and simultaneously off load the data to 2 drives with 5 separate folder destinations?
Matthew.
Jeremy Garchow
Re: Multiple ShotPut Pro running at the same time
on Jun 10, 2009 at 3:13:22 pm
Sure can. You start each card one by one, but you can use Shot Put Pro to offload 5 cards at once.
Matthew Romanis
on Jun 10, 2009 at 10:10:46 pm
Thanks Jeremy,
I tried that and got an application conflict error and a file in/out error.
Is there a known software conflict? I might have something loaded that's causing an issue.
Matthew.
Jeremy Garchow
on Jun 10, 2009 at 10:21:25 pm
Make sure you have the latest up to date Shot Put Pro and the PCD35 drivers.
Matthew Romanis
on Jun 11, 2009 at 10:54:00 pm
Yep, all that.
I've been checking on some other sites and the suggestion is that having Perian loaded can cause issue with some P2 applications. Has anyone experienced this?
Matthew.
