Will HPX-170 output SD-SDI?
COW Forums : Panasonic Cameras
Craig Bernstein
on Jun 6, 2009 at 12:47:44 am
I need to hook an HPX-170 up to an SD-SDI only piece of gear (Newtek Tricaster Broadcast).
Does anyone happen to know if the BNC [SDI] OUTPUT on the HPX-170 is switchable between HD-SDI and SD-SDI?
Thanks in advance.
Steve Eisen
Re: Will HPX-170 output SD-SDI?
on Jun 6, 2009 at 1:35:50 am
It will automatically detect it. You do have to make sure that the setting is set for SDI out.
AV IN/OUT Setup: SDI=On
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group
Jan Crittenden Livingston
on Jun 7, 2009 at 1:13:50 pm
And there is a menu item where you have to choose 480i as your output if you are looking to do a downconvert and send to a SD monitor.
Best,
Jan
Product Manager, HPX500, HVX200, DVX100
Panasonic Broadcast & TV Systems
