Only portions of clips imported
COW Forums : Panasonic Cameras
Josh Greenbaum
on May 26, 2009 at 7:52:37 pm
After searching the board, I've found out that a half circle in the status column means that only part of the clip was imported, and usually has to do with whether or not you set ins and outs before transferring. In my case, NO ins and outs were marked, but I still only get a partial clip. Any insight out there?
--josh
Shane Ross
Re: Only portions of clips imported
on May 26, 2009 at 11:48:21 pm
The footage was spanned across multiple cards? Mount all the P2 card dump folders.
Shane
