real size of the image in the CMOS
COW Forums : Panasonic Cameras
Pablo Mereu
on May 18, 2009 at 11:43:14 pm
Hi everybody, it's my first post, and I need some help...
somebody knows the real size of the active image in the Panasonic HVX - HPX???
Ok, we know that the HVX's CMOS size is 1/3". But, this is the real size of the image? or no?
I guess not.
I was searching this f**king number, but i didn't found it nowhere. I need this to calculate the size of the scenery that we will need relative to the camera lens.
Thanks!! (and sorry for my poor english)
Pablo
David Ziegelheim
Re: real size of the image in the CMOS
on May 19, 2009 at 11:44:15 am
http://www.dpreview.com/news/0210/02100402sensorsizes.asp
Pablo Mereu
on May 19, 2009 at 1:28:55 pm
David, thanks for the quickly response
I realize that isn't there the size of the P2 sensor. And neither is 16:9. I'll check this info and make calculus.
thanks!
John Fishback
on May 19, 2009 at 3:04:48 pm
If you are trying to calculate the width and height of your set then I think all you need is the picture size ratio of width to height or 16:9. Some sensors produce images with this ratio, but their actual dimensions are different. So, 16/9 would equal width/height. If your set is limited by height, plug in that number and you can calculate the width (W = 16H/9) or vice versa (H = 9W/16). I hope that's right. It's been a while since algebra.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24" TV-Logic Monitor
Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
