HPX171E 720p50
COW Forums : Panasonic Cameras
Caesar Heyne
HPX171E 720p50
on May 14, 2009 at 12:49:27 pm
Is the 720p50 the best quality setting for the HPX 171? Ending up in DVCPRO HD 14,1 MB/sec 960x720 in FCP. Looks a little grainy!
Thx Caesar
Jeremy Garchow
Re: HPX171E 720p50
on May 15, 2009 at 4:47:06 am
Have you played with the gamma or settings of the camera at all?
Latest firmware?
Caesar Heyne
Re: HPX171E 720p50
on May 15, 2009 at 9:30:35 am
Played with the settings, but I'll check the firmware, I'll be back. thx
John Fishback
Re: HPX171E 720p50
on May 15, 2009 at 4:26:10 pm
Test with some of the scene files from Panasonic that come with the camera before changing any settings. If you check out the PASS website, https://eww.pass.panasonic.co.jp/p2ui/Login.do you can download the scene file handbook. It explains how to adjust settings. Also check your gain setting on the camera, If it's set to boost you'll have more grain.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
24" TV-Logic Monitor
Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
