fcp 4.5 and the hvx200
COW Forums : Panasonic Cameras
Jimmy Matlosz
on May 12, 2009 at 9:58:05 pm
ok so for those of us who arent editors, Im a DP, and who have a stoneage fcp system 4.5, can I import hvx200 native footage into fcp4.5? I was under the impression Im lacking a plug in.
thanks your the best
jim matlosz
dp, la, ca
Jim Matlosz
DP, LA, CA
Jeremy Garchow
Re: fcp 4.5 and the hvx200
on May 13, 2009 at 12:24:39 am
FCP does not edit native MXF files on any current version.
I believe FCP5 was the first version to allow rewrapping of MXF files to QT.
What do you need to do?
Jimmy Matlosz
on May 13, 2009 at 2:05:24 am
I was afraid of that. I recall back when the hvx was introduced that 4.5 would not be compatible.
anyway, and generally i dont bother editing my own stuff that i capture with the hvx, but this is a smaller project and a favor, so limited budget and resources.
what i am doing is, Im shooting with the hvx and want to edit or at least transcode the footage to quicktime, as far as i know there are only two ways to transcode and that is fcp or after fx.
Jim
Jim Matlosz
DP, LA, CA
Jimmy Matlosz
on May 13, 2009 at 2:07:22 am
i dont usually edit the native hvx files, but this is a smaller job Im doing as a favor. i only have 4.5.
even if there was a way to transcode to quicktime that would be great.
Jim
Jim Matlosz
DP, LA, CA
Jeremy Garchow
on May 13, 2009 at 1:52:39 pm
Do you know anyone with FCP 5 or higher? You can transcode the files on their machine and take the QT file with you.
P2 Log Pro from imagine products will transcode your files to quicktime, but that will cost money.
Jeremy
