AVC-i demo material
COW Forums : Panasonic Cameras
Margus Voll
AVC-i demo material
on Apr 19, 2009 at 6:57:00 am
Hi.
Is there eny place where i could get some demo material to check out work flow etc ?
Do i get it right that i have to render all stuff out before i can edit on FCP?
Margus
http://iconstudios.eu
Matthew Romanis
Re: AVC-i demo material
on Apr 19, 2009 at 7:14:54 am
I don't know where you would get some test material, but technically you need FCP 6.0 or later, an Intel equipped MAC, and P2CMS software from Panasonic.
You don't render vision, you need to transcode it. FCP can't use AVC intra 50/100 material natively yet as it has no way to interpret the 10 bit stream natively. A function in FCP called LOG and TRANSFER will transcode all the AVC intra 50/100 MXF files into QT Apple Pro Res 422/HQ material. Depending upon your processor speed, this will work at close to real time up to 2 times longer in some situations.
The P2CMS software is good for problem solving the MXF files in the FCP environment.
