P2 Transfer Question
COW Forums : Panasonic Cameras
Chris Bierlein
on Apr 16, 2009 at 4:43:04 pm
I shot a talking head on a green screen a few weeks ago using the HVX at 720P 24PN. It was properly lit and exposed. The production company/post house is now trying to key and is having a rough time-jagged edges, artifacting, etc. We're tracing the problem back as far as we can, and it appears that in the originally transferred footage (post quicktime conversion), resolution looks low-kind of like a low rez jpeg. They haven't gone to the original MXF files yet-working on finding those now. My question is this...is there somewhere between inserting the card in the reader on the set, and opening the converted quicktime in FCP6, that resolution could be degraded or additional compression could take place?
Chris Bierlein
http://www.chrisbierlein.com
Michael Sacci
Re: P2 Transfer Question
on Apr 16, 2009 at 5:38:20 pm
Nope, all the FCP is muxing the audio and video together, while wrapping the data in a QT .mov wrapper. The codec is always DVCProHD.
What is the files displaying in the bin columns?
Chris Bierlein
on Apr 16, 2009 at 6:01:01 pm
The files are reading what they should: DVCPRO HD, 960X720, 23.98, etc. Bitrate is 5.9mbps. A 6 second test clip is about 35MB which by my math sounds right. It just doesn't add up. The picture has all the qualities of a low rez jpeg. We just reimported a test file from the MXF and it's the same. Very puzzling.
Jeremy Garchow
on Apr 16, 2009 at 5:37:04 pm
[Chris Bierlein] "hat resolution could be degraded or additional compression could take place? "
No. It is a simple rewrap from MXF to DVCPro HD in where the audio and video get joined. The resolution is exactly the same. What are they using to key the images?
Jeremy
Chris Bierlein
on Apr 16, 2009 at 6:20:55 pm
They're keying with AE and Keylight.
Jeremy Garchow
on Apr 16, 2009 at 8:45:05 pm
Any chance you can post a little bit of this footage?
Chris Bierlein
on Apr 17, 2009 at 1:00:18 am
Will post something this evening. Would love the group's opinions.
Chris Bierlein
on Apr 17, 2009 at 3:14:15 am
Here's a clip from the shoot...
http://www.chrisbierlein.com/Site_2/Questionable_HVX_Footage.html
Love to hear your thoughts.
D. Scott Dobbie
on Apr 17, 2009 at 5:14:48 am
Unless my eyesight got really bad all of a sudden, I don't see a problem with the footage. Looks clean except for when talent throws his arms forward at the end. Even "double-size" in QuickTime looks pretty good - though no longer sharp. But I don't see jaggies.
Perhaps it's not being viewed at full resolution on FCP.
Is your post house merely reporting this to you or have you actually seen it on their system?
Chris Bierlein
on Apr 17, 2009 at 2:49:09 pm
Yeah, I agree. It looks OK to the eye. It's when you try to key it that the crazy jaggies become apparent. That's what's so confusing. I've done simple keys in FCP with HVX footage before (for preview purposes only) and it looks nice and clean around the edges, but this clip is a mess! Love to hear your thoughts, if you're able to try a key.
Jeremy Garchow
on Apr 17, 2009 at 4:45:59 pm
Pixel Dimensions come up as 300x225?
Jeremy Garchow
on Apr 17, 2009 at 4:57:20 pm
Operator Error. i saved it incorrectly. I got it now.
Jeremy Garchow
on Apr 17, 2009 at 5:47:08 pm
Looks like HVX footage to me, not a low res jpeg. You will have a bit of trouble keying the hair
Jeremy
Chris Bierlein
on Apr 17, 2009 at 6:05:25 pm
Try keying it. That's when the problems arise. Looks way worse than other HVX keys I've done.
Jeremy Garchow
on Apr 17, 2009 at 5:58:56 pm
OK, here's a quick (a few clicks) key with Keylight and saved down to low res JPEG.
Jeremy
D. Scott Dobbie
on Apr 17, 2009 at 6:19:05 pm
That looks clean, Jeremy.
Chris, have you worked with that post house previously? Can you upload a shot showing the jaggies?
Chris Bierlein
on Apr 18, 2009 at 7:39:07 am
Hey everyone, Thanks for the help and responses! Jeremy, your key looks great. Did you have jaggies at first, and then soften the edges? Apparently the post house has come up with a fix, but I don't know what it is yet. Check out the Jaggies. I did this in FCP, but the post guys were using AE and had the same result.
Softening the edges helps alot, but I'm know it shouldn't look so "jaggy" in the first place.
Chris B
Jeremy Garchow
on Apr 18, 2009 at 4:24:26 pm
[Chris Bierlein] "Did you have jaggies at first, and then soften the edges?"
No, not jaggies like that. I applied a tiny amount of blur, but really not that much.
Chris Bierlein
on Apr 17, 2009 at 6:50:16 pm
On the road all day away from computer. Will check out and respond tonight!!! Anxious to see your results.
