• | Firestore to P2 problems ~
on Apr 13, 2009 at 8:49:01 pm |
I've tried looking for any help on this
we use the Firestore fs-100
we also have a P2 card we use for smaller things
well during an event the usual Firestore crap happened where files become un-readable
however i noticed that we could play and watch the file thru the firestore into the camera
i called firestore and they said i could copy the bad files to the p2
did that
now final cut pro won't log and transfer the footage probably....
like i get video no audio
choppy footage etc
does anyone know the process for this case ?/
• | Re: Firestore to P2 problems ~ on Apr 13, 2009 at 11:42:04 pm |
What are all your settings? Sounds like a mismatch between the Firestore's footage and the camera's settings.
• | Re: Firestore to P2 problems ~ on Apr 14, 2009 at 12:16:32 am |
it could be
basically i took my firestore and i connected it to the camera
pressed play record on the camera
and than play on the firestore
which recorded it to my p2 card...
when i play back the p2 card it plays fine
to get it into fcp...well that's another story
it's coming up in log and transfer
but it will also play thru in log and capture
problem with that is it shuts off with timebreak errors
• | Re: Firestore to P2 problems ~ on Apr 14, 2009 at 3:46:20 am |
What was your shooting mode when you recorded to the Firestore?
How was the Firestore setup?
How is the Camera setup when you try to record back to the P2?
These things should not be assumed to be correct. [Arty Gold] "problem with that is it shuts off with timebreak errors "
What is IT, the Firestore? FCP capture?
