24pa interpreted as 29.97..why?
COW Forums : Panasonic Cameras
Ben Young
on Apr 13, 2009 at 6:34:33 pm
Hi, I recently bought a HVX200 and am new to the workflow. I recorded at 24pa, intending to work in 24fps in Adobe. My project file is set at 24fps, the camera was set at 24pa. When I import the footage, AE and Premiere interpret the footage as 29.97. Dragging that footage to the timeline, it appears interlaced.
If I want to work in 24fps, how do I get it to correctly interpret the footage from my camera? If I change the frame rate the footage is interpreted at to 24fps, I'm worried the audio might be off.
Any help? Thanks!
Dave LaRonde
Re: 24pa interpreted as 29.97..why?
on Apr 13, 2009 at 9:34:45 pm
The following blurb is from the HVX200 Overview portion of Panasonic's own web site:
"Supports 1080/60i, 1080/24p, 1080/24pA, 1080/30p, 720p/60p, 720/24p (over 60p), 720/30p (over 60p), 720/24pN native, 720/30pN native 480/60i, 480/24p (over 60i), 480/24pA (over 60i), 480/30p (over 60i)"
So you'd have to find a way to remove the pulldown. Like you, I'm still learning about the camera.
Dave LaRonde
Sr. Promotion Producer
Shane Ross
on Apr 13, 2009 at 9:45:07 pm
1080i 24PA...yeah, records 24p in a 29.97 stream Gotta remove pulldown. Dunno how you do that with CS3 or CS4.
Shane
Vince Becquiot
on Apr 14, 2009 at 6:06:03 pm
In Premiere select the clip, right click > interpret footage and remove 24P DV pulldown.
Vince Becquiot
Kaptis Studios
San Francisco - Bay Area
