HPX170 direct to hard drive?
COW Forums : Panasonic Cameras
Joel Diament
on Mar 28, 2009 at 3:18:17 pm
Hello,
Can you shoot footage on the HPX170 straight to hard drive? If so, is USB 2.0 too slow?
Joel
Jeremy Garchow
Re: HPX170 direct to hard drive?
on Mar 28, 2009 at 6:54:35 pm
[Joel Diament] "If so, is USB 2.0 too slow? "
Yep. You need at least fw400, but I'd recommend an ioHD, a laptop and a two drive SATA array. That way you can capture straight to ProRes or ProResHQ and remove and redundant frames on the fly. If you are going to go through the 'trouble' of doing a live capture, I'd make sure you are getting the best quality possible.
Jeremy
