AJ-PCS060 and 64GB P2 cards
COW Forums : Panasonic Cameras
Norm Nusbaum
on Mar 18, 2009 at 8:36:23 pm
I have tried to download files from a 64GB P2 card to my AJ-PCS060 portable hard disk and keep getting error message that an unusable P2 card has been inserted. The card only has three short scenes, so it is not anywhere near full. The hard disk unit works fine with an 8GB card. I have checked and it looks like I have up-to-date firmware. Any suggestions? Does this just not work with a 64 GB card? Thanks
Jeremy Garchow
Re: AJ-PCS060 and 64GB P2 cards
on Mar 18, 2009 at 10:30:16 pm
With the P2 store, a partition is created for the total file size of the card, not just how much data is on the card. So in your case, the 64Gig card won't fit on a 60 Gig drive.
Jeremy
Norm Nusbaum
on Mar 18, 2009 at 11:07:46 pm
Thanks. It makes sense from a technical standpoint. From a practical standpoint, it means I can only download onto the disk with my 8GB cards...which is not good.
Jeremy Garchow
on Mar 19, 2009 at 12:06:26 am
[Norm Nusbaum] " it means I can only download onto the disk with my 8GB cards...which is not good."
Can't fit a square peg in to a round hole unfortunately. As has been mentioned, you can use the p2 store as a USB reader and transfer the footage off of the card to a laptop or other disk drive.
Jeremy
Jeremy Garchow
on Mar 19, 2009 at 12:08:57 am
Wait, is this Norm in Vegas?
If so, howdy. It's Jeremy from Maday. We rented a couple of lights for you back in December for the Harley Davidson shoot. Friends with Murphy?
Jeremy
Dave Neyman
on Mar 18, 2009 at 11:23:16 pm
Jeremy is right. Consequently the P2 store will only hold one 32 GB card. They are only useful anymore for a few 16 GB cards or as a USB reader.
Norm Nusbaum
on Mar 19, 2009 at 4:46:10 pm
Jeremy: Yes, it's me. Thanks for your reply. Hope all is well.
Jeremy Garchow
on Mar 19, 2009 at 5:10:30 pm
You too, Norm. Feel free to call with any questions, any time.
Jeremy
Troy Lanier
on Mar 8, 2010 at 3:00:10 pm
I would like to use my P-Store as a USB reader for 64GB cards, but I am on a Mac. It looks as if I cannot upgrade the firmware to even read a 64GB card unless I have access to a PC. Can anyone confirm this?
Jeremy Garchow
on Mar 8, 2010 at 4:25:38 pm
[Troy Lanier] "Can anyone confirm this? "
This is true.
That being said, I am not sure if you need to update the P2 Store for 64GB cards. The last time the firmware was refreshed for that thing was in May 2007.
Jeremy
Norm Nusbaum
on Mar 8, 2010 at 5:44:54 pm
I have that P2store and 64 GB cards. And while you cannot download the cards onto the P2 store, what I do is open Final Cut, then hook up the P2 store to my mac. I insert the card (it should appear on the Mac desktop, but I don't use that). Then on Final Cut I go to FILE > Log and Transfer. Then files on the P2 card show up on the Log and Transfer and I select which files to bring into Final Cut, I also dupe those files onto another hard drive so that I have a backup for when I have to erase the P2 card.
Giuseppe Fedele
on Dec 10, 2010 at 10:09:45 am
Then you can use it as a card reader to 64GB or not? Thanks.
