Is this lens compatible with the hvx200?
COW Forums : Panasonic Cameras
Rock Well
on Mar 12, 2009 at 6:31:47 pm
New to forum, if I double posted, I apologize.
I purchased the item below:
http://www.amazon.com/gp/product/B001G0OLS0
This lens says its for the hvx200, but it doesn't fit (too small). Is there some sort of adapter I need, or is this lens just not compatible?
Thank you,
Rock
Steve Eisen
Re: Is this lens compatible with the hvx200?
on Mar 12, 2009 at 7:27:18 pm
Filter diameter on the HVX-200 is 82mm not 72mm.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group
Rock Well
on Mar 13, 2009 at 12:31:19 am
Thank you.
Well that sucks. What a waste.
Rock Well
Can I use a step-up ring, what will that do to picture?
on Mar 13, 2009 at 12:41:45 am
I see there are step-up rings that can adapt 72 mm to 82mm.
What exactly will this do to the quality? Create a black ring on the edges?
Sorry for the dumb questions.
Steven Rushworth
Re: Can I use a step-up ring, what will that do to picture?
on Mar 28, 2009 at 6:09:39 pm
Yes, its highly likely it will vignette.
