Need help with the VFR function
COW Forums : Panasonic Cameras
Roli Rivelino
on Mar 5, 2009 at 3:33:00 pm
I'm trying to test the VFR function on my HVX 200 and I've gone to REC FORMAT and selected 720/25PN, I've then gone into SCENE FILE and selected FILM CAM but when I try to go to FRAME RATE it just says default and doesn't give me any options to change.
I wasn't using my firestore at the time;
I need to know how to adjust the frame rate on the camera first and I guess the firestore as well.
many thanks.
Michael Sacci
Re: Need help with the VFR function
on Mar 5, 2009 at 4:08:25 pm
Was the default in BLUE?
If you are going to Firestore you cannot use pN mode, that mode does not go through the firewire port. Use have to use normal P and then VFR setting on the Firestore which removes the redundant frames.
Roli Rivelino
on Mar 5, 2009 at 4:25:25 pm
OK thanks, I think I get that as far as the firestore is concerned (still learning!) but as far as the DEFAULT is concerned it's written in green.
Michael Sacci
on Mar 5, 2009 at 4:28:53 pm
You navigate down to the frame rate and press the button in and then all the frame rates are available to scroll up and down then select what you want.
Roli Rivelino
on Mar 5, 2009 at 5:53:43 pm
ah thanks, I was being a bit dim there, I expected them all to be laid out in menu form.
many thanks
