Best Way to downconvert
COW Forums : Panasonic Cameras
Waldo Chan
on Feb 16, 2009 at 12:10:24 am
I am asking the best way to make the downconvertion in order to keep best quality possible because I have an 1080 edition with panasonic hpx2000 and need to record at Standard def….
1. solution is making downconvert through the aja Kona Lhe
2. dragging the 1080 edition to a new 720 x 486 sequence inside final cut(no export needed).
3. Exporting an uncompressed 10 bit 1080 quicktime and then import to 720 x 486 uncompressed 10 bit sequence in final cut.
Thank you for your time..
Waldo
Shane Ross
Re: Best Way to downconvert
on Feb 16, 2009 at 1:22:42 am
Option 1...downconvert thru the Kona.
Shane
