Frame Rate Problems
COW Forums : Panasonic Cameras
Greg Burke
Frame Rate Problems
on Jan 29, 2009 at 2:29:13 am
Greetings all, I'm having trouble setting frame rates on the HVX and HPX, I set to 720p/60p , it's on Film cam, and I set Frame rate to 60fps,18fps etc, then when i play back the footage in camera it looks like 29.97, them when i import the footage into Final Cut the file is 29.97. I'm completely lost I was working with this camera for a good 2 hours trying to solve this problem but couldn't. Can anyone out there help me?
-Greg
Shane Ross
Re: Frame Rate Problems
on Jan 29, 2009 at 6:39:56 pm
OK, first off, did you set the SCENE FILE to 24 Frame, as well as having FILM CAM? Sounds like you did.
NOW, in recording setup, what REC FORMAT do you have?
Shane
