p2 low rez proxies relinked to original MXF p2 files
COW Forums : Panasonic Cameras
Steven Brown
on Jan 23, 2009 at 7:40:54 pm
Does anyone know of a workflow that has down rezed P2 files for Avid offline editing and then using the original P2 files for realinking in online?
Or: does anyone know of a program that can create a proxy of P2 files that can be used for offline and subsequent relinking in Avid?
Shane Ross
Re: p2 low rez proxies relinked to original MXF p2 files
on Jan 23, 2009 at 8:56:32 pm
Avid does this itself. When you import the P2 files Avid just points to the existing files. Now, you can either Consolidate those files to you media drive, or you have the option to Recompress to the media drive. Recompress 15:1.
Now I haven't tested this, so you should. But in theory it should work.
Shane
