Duel adaptor or P2 reader PCD20
COW Forums : Panasonic Cameras
Frank Bokoski, Jr.
on Jan 19, 2009 at 11:58:59 pm
Need help ASAP cause we're ordering tomorrow!! Here is our situation: We are making the move to P2 and shooting about 32 to 40 hours of footage next week, basically run and gun but bringing a crew member to offload p2 cards to hard drive. This is a two camera shoot by the way so there will be several p2 cards flying around.
We're trying to figure out the best system to do this on the run yet still get redundant (if possible) verified backup while in the field. We were about to settle on the PCD20 card reader when I started seeing thread for the Duel adapter. Yes, we are using a macbook pro. What are your opinions? Can the card reader copy over more than one p2 card at a time using offload software (I think we're getting ShotPut p2)? Is it best to get separate hard drives or a raid1?
Thanks in advance for you help.
1615, The GC Media Project
http://www.1615.tv
http://www.powerplayersradio.com
themovieIAM.com
Noah Kadner
Re: Duel adaptor or P2 reader PCD20
on Jan 20, 2009 at 1:14:49 am
Definitely the PCD20 if you can afford to buy one or rent it. Folks talk about crashes with the Duel all the time and at the end of the day it's only one slot vs. 5 on the 20. Much more simple workflow.
Noah
Check out My My FCP Blog and my new RED Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color.
Now featuring the Sony EX1 Guidebook,
DVD Studio Pro and How to Light Interviews.
http://www.callboxlive.com
Frank Bokoski, Jr.
on Jan 20, 2009 at 3:26:52 am
Thanks Noah. Do you have any experience with the P2 gear? Does it do a a good job of uprezing 720 to 1080? It's really expensive but we're considering that too.
http://www.1615.tv
themovieIAM.com
Jeremy Garchow
on Jan 20, 2009 at 4:52:36 am
PCD20, no doubt about it. If you are on a multicam shoot, a PCD20 is almost a must.
Frank Bokoski, Jr.
on Jan 20, 2009 at 4:57:29 am
PCD20 it then. Thanks guys.
One more question: What hard drives are you folks using in the field to offload the P2 cards to. Bus powered or not? Lacie?
thanks
http://www.1615.tv
themovieIAM.com
Jeremy Garchow
on Jan 20, 2009 at 5:15:44 am
Well,we use a combo of a few things. I use this sometimes:
http://www.sonnettech.com/product/fusionf2.html
but then we also have a cheap two drive enclosure from StorTech or StarTech (I can't remember) that we run JBOD and use Shotput Pro to offload the p2 cards to two drives simultaneously (it can handle up to three if you have them). That way those two sata drives eventually become the archive as sata drives on the shelf. Right now we have about 19 or 20 TB of storage sitting on the shelf in duped SATA drives. We are waiting for the right option for longer term, more safe and relatively cost effective storage to come along, but it hasn't hit us over the head yet.
ALso in a pinch we use a weibetech fw800 to SATA converter that allows us to attach bare sata drives to it. No enclosure necessary.
Jeremy
