Slow motion on HPX2000
COW Forums : Panasonic Cameras
Waldo Chan
on Jan 19, 2009 at 3:56:00 pm
Can I make slow motion in hpx2000?
I am recording 1080i 59.94 at 60fps (AVC-INTRA 100), then I make log and transfer, but when I saw the clip in the bin area, it says it is at 29.97fps, then I go into the capture scratch folder and search that clip, and open with cinema tools and conform to 23.976..
And it change to 23.98.. but I dont see the slow motion effect
What I am doing wrong? Is that ok, that final cut says my footage its original at 29.97 fps and not 60fps?
Thank you for your time..
Waldo
Jeremy Garchow
Re: Slow motion on HPX2000
on Jan 19, 2009 at 9:33:45 pm
Well, you won't get much of a speed change that way. If you want to get slow motion from 1080i60 material, try this:
http://www.rarevision.com/articles/slow_motion.php#
OR
You can shoot 720p60 and then conform that to 23.98 in Cinema Tools and use that scaled up in a 1080psf23.98 timeline. You are still editing in a 23.98 timeline, yes?
Jeremy
