audio in log and transfer--try this
COW Forums : Panasonic Cameras
David Coleman
on Dec 17, 2008 at 3:17:56 pm
I've had this bug intermittantly and it drives me crazy. You open log and transfer like before, but this time you can't hear the audio, so you can't log and transfer sound bites. Restarting sometimes helps, but not always. And no, it isn't a Easy Setup issue or Audio/Video settings.
I don't know if it is a fix, but today restarting FCP or the Mac didn't help. Refreshing AV devices under the view menu did (alt-f12), however. Your mileage may vary, but give it a try when rubbing the lucky rabbit's foot doesn't.
David
Shane Ross
Re: audio in log and transfer--try this
on Dec 17, 2008 at 4:05:29 pm
Thanks for this. Very useful information. I will pass it on.
Shane
sam Waldorf
on Dec 19, 2008 at 3:15:29 am
I've run into this problem as well. Usually I just quit and reopen and it fixes itself.
Am I correct in assuming no one knows the cause of this?
