best progresive mode for hvx 200
COW Forums : Panasonic Cameras
john alexander
on Oct 4, 2008 at 11:13:09 am
Hello
which is the best format to shoot on the hvx in true progressive.
1080i/25p or 720p/25p. noticing that the 1080i/25p is an interlaced scan but has a progressive frame rate?
thanx
Jeremy Garchow
Re: best progresive mode for hvx 200
on Oct 4, 2008 at 4:35:59 pm
The HVXs initial scan is Progressive, then the other formats are disseminated form there. 1080i/25p is psf (a progressive image in an interlaced wrapper). 720p is 'true p' as it were. Wither way, you are getting essentially a progressive image as long as you render without fields in your NLE when working in 1080. 720p is always progressive.
Does that help?
Jeremy
john alexander
on Oct 4, 2008 at 8:55:58 pm
Yep sure does, thanks..
but is 1080 25p a better format in visual quality in progressive, than the 720p 25p?
thanks..
Noah Kadner
on Oct 4, 2008 at 9:04:42 pm
There's no right answer. It's up to you. Personally I prefer 720p- that is the native format and give you more variable frame rate options so that's what I shoot. But maybe you have to deliver in 1080 in which case that's your answer.
Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
Now featuring the Sony EX1 Guidebook, DVD Studio Pro and Sound for Film and TV.
http://www.callboxlive.com
