72024p workflow from FCP 5.1.4 to AE 6.5
COW Forums : Panasonic Cameras
aleigh lewis
on Oct 4, 2008 at 1:25:58 am
I shot with the HVX200 for the first time using 720, 24p. I shot against green screen and need to go to AE to do compositing.
My understanding is that Panasonic is DCVPRO but my export options in FCP 5.1.4 are:
DVCPRO HD 1080i50
DVCPRO HD 1080i60
DVCPRO HD 50p
DVCPRO HD 60
or:
HDV 720p24
which of these do I choose? Or do I need to move to FCP 6?
My second question is if it is possible to use AE6.5 for this? When I choose my composition settings the only option is: HDTV 1280x720.
I appreciate your response in advance!
Thank you,
Aleigh
Shane Ross
Re: 72024p workflow from FCP 5.1.4 to AE 6.5
on Oct 4, 2008 at 4:22:49 pm
Export a Quicktime Movie...self contained using the sequence settings. This gets you a quicktime file that is lossless.
Avoid HDV...that is NOT DVCPRO HD, and will make it look worse.
1280x720 is the dimensions of DVCPRO HD. AE has DVCPRO HD as a codec.
Shane
aleigh lewis
on Oct 5, 2008 at 1:44:47 am
Hi Shane,
thank you for your response!
i still have one question, in AE6.5 the composition settings option says: HDTV 1280x720...and when i import the file, it is smaller than the window that it creates for those composition settings. ?
I am trying to figure out if 6.5 has settings for 720 24p.
Aleigh
Shane Ross
on Oct 6, 2008 at 1:08:57 am
After you chose those settings, did you choose NEW COMPOSITION? ANd is it smaller all around? Or just on the sides?
Shane
