Print to Video Issues
COW Forums : Panasonic Cameras
Jason Pence
on Sep 30, 2008 at 3:31:18 am
Good evening everyone,
I'm trying to do a print to video recording. My MBP recognizes my HVX, and it actually records all the audio for the 30 sec spot; the problem is it's not recording the video. It'll record the first second of bars, then it's if the firewire/video transfer can't keep up with output of the timeline. Prior to trying to recording, I can scroll through the timeline and see the entire video on the LCD of the camera, it's only when I try and record, I loose the video signal. Humm......?
Any ideas?
Many thanks,
Jason
Jeremy Garchow
Re: Print to Video Issues
on Sep 30, 2008 at 4:09:12 am
What format are you working in?
Jason Pence
on Sep 30, 2008 at 4:15:11 am
HD 960x720. The kicker is, is that is has to be 4:3 for broadcast and transferred onto Beta SP. I have a very simple system and have to go elsewhere for the Beta transfer.
Jason
Jeremy Garchow
on Sep 30, 2008 at 4:37:05 am
Why don't you take the finished file over to a dub house? You can't do this to tape if that's what you're trying to.
Jason Pence
on Sep 30, 2008 at 4:47:25 am
Or
I may have to do it all a a dub house. Any recommendations in San Diego :)
Jason
Jeremy Garchow
on Sep 30, 2008 at 5:12:52 am
Sorry, I don't. But I am sure there is a service out there to layoff your project for you.
Jason Pence
on Sep 30, 2008 at 5:40:03 am
One last thing... my last message was partially deleted....
What about using Compressor to down-convert and crop to the final video? I guess it would then end up being a 4:3 letterbox? And if so, then could I edit to video in FCP6?
Best
Jeremy Garchow
on Sep 30, 2008 at 1:26:16 pm
Do you have a Beta deck and a capture card to lay this off with? If not, just take the exported self contained HD movie to the dub house.
Jeremy
Richard Herd
on Sep 30, 2008 at 4:20:42 pm
Not speaking from experience here, but ... if you're trying to print an HD sequence to a miniDV tape, then that poses a real problem. MiniDV is okay with 48k 16-bit audio, so that could be why it's showing up.
Just a thought: Export the sequence using compressor to DV codec, then re-import the spot, and open the DV spot in a DV timeline, print to tape, see what happens.
