Output DVCPro50 over FireWire / DV?
COW Forums : Panasonic Cameras
Niklas Wikman
on Aug 11, 2008 at 1:57:37 pm
We shoot 576i 16:9 over DVCPRO50.
We have a Sony DSR-45P DVCAM-deck connected using Firewire for monitoring video.
What settings in FCP should we have so we can output the timeline/canvas over FireWire using the DSR-45P?
We had the HPX500 for test shooting and managed to get it work at that time. Now we can't find what setting(s) to modify...
Any help greatly appreciated!
Shane Ross
Re: Output DVCPro50 over FireWire / DV?
on Aug 11, 2008 at 7:12:50 pm
You can play out DVCPRO 50 over firewire, but not through a DV device. It needs to be a DVCPRO 50 deck, or DVCPRO HD deck...one capable of decoding the signal you are sending to it. DV decks and cameras cannot decode DVCPRO 50.
Shane
Niklas Wikman
on Aug 11, 2008 at 8:43:23 pm
Somehow we managed to view the footage recorded in DVCPRO50. However, I think there's a compressor preset in FCP that I wonder about. If I recall correctly, it's set for DVCPro50.
What happens when you use LOT in FCP and the preset are wrong? Will the QT files have wrong codec, or will FCP / LOT maintain the original DVCPRO50 set i camera?
Shane Ross
on Aug 11, 2008 at 9:44:53 pm
Log and Transfer? That imports at whatever resolution the footage was shot...no recompression. So no matter what settings you have in FCP, it will import as shot. Is this coming from P2?
Shane
Niklas Wikman
on Aug 12, 2008 at 6:47:19 am
Yep, comes from offloaded P2 cards.
Niklas Wikman
on Aug 12, 2008 at 9:06:44 am
The only thing now is that I always end up with red stripes when I drag P2 clips onto the timeline.
If you can tip me on what presets (modified or not) I should use, I'd be very glad!
