Battery waring already at 70% with AB Hytron 50
COW Forums : Panasonic Cameras
Niklas Wikman
on Aug 2, 2008 at 8:17:45 pm
Another odd thing: putting on one of our fully charged Hytron 50 gets the 500 to start warning for low battery already at 70%. Is this normal when using the AB batteries in the beginning? The batteries are previously used on a Sony PVV-537P.
The camera is set for Hytron50 / Auto.
Steve Eisen
Re: Battery waring already at 70% with AB Hytron 50
on Aug 3, 2008 at 2:23:50 am
You can manually change the low battery indication in your settings.
Steve Eisen
Eisen Video Productions
Board of Directors
Chicago Final Cut Pro Users Group
Niklas Wikman
on Aug 3, 2008 at 6:28:57 am
OK. I'll have to do some testing then, to find out which voltage that match the battery. I assumed the presets were designed for the specific battery type voltage, but obviously not? :-)
Adam Smith
on Aug 3, 2008 at 7:16:22 pm
My Hytron 50's have worked fine with light use for about a year, but just the other day I stuck one on and got a battery warning and then power down... at a viewfinder-displayed 80% capacity. The window on the battery itself showed nearly full, and this battery had been fully charged the previous day, used very little, and removed from the camera overnight.
I triple checked it and could not figure what the issue was. Another partially used (50% or so) battery was connected and worked just fine. Never did figure it out, but it's awful scary to think I could get to a job and have a full battery refused by the camera.
I suppose perhaps I should look into setting things manually as well.
Video Photographer / Avid & Final Cut Editor
