Live capturing HD footage from HVX to FCP
COW Forums : Panasonic Cameras
Tinx Chan
on Apr 26, 2008 at 3:36:12 pm
Hey,
I was wondering if it were possible to live-capture 1080 or 720 footage via firewire straight from the HVX into Final Cut?
i know it's doable in standard def, but hd i'm not so sure of...
-Tinx
Nate Stephens
Re: Live capturing HD footage from HVX to FCP
on Apr 26, 2008 at 6:44:11 pm
Tinx,
It works great.. 1080 Firewire (32feet) to Mac Book Pro with Capture Now - Final Cut Pro to xpress card sata mirrored raid... Over 2+ hours and NO drop outs or other problems..
When you consider the cost of P2 cards and if you don't mind being tethered to a computer, it is almost cheaper.... this way..
Tinx Chan
on Apr 28, 2008 at 4:13:40 pm
Thanks Nate.
Bob O'Brien
on May 20, 2008 at 12:03:05 pm
Nate,
When outputting HD over firewire to MacBook Pro (fcp), can you also record SD to miniDV at the same time?
Thanks.
Bob
*DualG5, 2gHz, w/5.1.4 firmware
*2.5 Mb RAM, 160 Mb SATA HD
*UL4D w/1.4.0f1 flash and 3.0.0 driver *HMV800 DualMax RAID0 Revision 511
*AJA IO w/20-21 firmware & v1.1r1 driver
*OSX10.3.2, QT 6.5, FCP 4.1.1, Livetype 1.1.1, Soundtrack 1.1, DVD
tinx chan
on May 20, 2008 at 12:26:16 pm
Nope.
When live capturing HD, you can't record to miniDV at the same time.
However, I'm pretty sure for live capturing SD-- you can capture miniDV.
Nate Stephens
on May 20, 2008 at 2:00:46 pm
Bob,
You need to ask Shane, our MXO specialist.... but I am pretty sure the Matrox MXO which you would plug into the DVi monitor port does real time HD to SD conversion. That MXO SD you could plug into a DV deck....
Good question
Bob O'Brien
on May 20, 2008 at 3:21:20 pm
Great idea. Since I do have an MXO, that sounds like a winner. I'll test it out.
Bob
Nate Stephens
on May 20, 2008 at 3:27:17 pm
Bob,
Since you have the MXO, how do you like it? How do you use it in your workflow?
Do you have the Matrox Dual or Triple head adaptors also?
I am updating my edit suite to the new Mac pro,, and Have been debating the value of the MXO..
Bob O'Brien
on May 20, 2008 at 3:35:34 pm
I use it for monitoring HD on a 23" Apple display while editing on my MacBook Pro. I use two LaCie eSATA drives attached to the MBP via an Expresscard adapter. It works great.
I really have not had the need to use the MXO in any other way yet, but am aware of its functionality as a downconverter. I'll give it a try.
Thanks again.
Bob
