CONTENTS
COW Forums : Panasonic Cameras
Stephen Franciosa
CONTENTS
on Apr 14, 2008 at 10:46:10 pm
How necessary is it to keep the CONTENT folder after the footage has been ingested into FCP and converted to Quicktimes?
Jim Carswell
Re: CONTENTS
on Apr 15, 2008 at 12:14:32 am
I'll ask you one question. Would you throw away your raw tapes? I think you would answer "no." Tossing your mxf files/contents is essentially the same thing as tossing your tapes.
Jim
Jim Carswell
Spyhop Productions, Inc.
Savannah, GA
http://www.spyhopproductions.com
Stephen Franciosa
Re: CONTENTS
on Apr 15, 2008 at 12:32:46 am
Well just figured the Quicktimes are the same thing?
Dave Neyman
Re: CONTENTS
on Apr 15, 2008 at 2:07:14 am
Do a search and look at old posts. This seems to come up every few weeks. You should NEVER dump the original files. After they are ingested into FCP as quicktime files they can only be read by FCP. What if you wanted to use the footage for something else? Jim's question of whether you would toss the master tapes is valid. Why would you?
Noah Kadner
Re: CONTENTS
on Apr 15, 2008 at 7:04:08 am
[Stephen Franciosa] "Well just figured the Quicktimes are the same thing?"
That would a big fat negatory. But you can find out all about MXF vs. .MOV by slinking through the forum a bit. Or read this:
http://www.dvfilm.com/raylight/mac/index.htm
-Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the Sony EX1 Guidebook
http://www.callboxlive.com
Michael Sacci
Re: CONTENTS
on Apr 15, 2008 at 3:02:25 pm
the other thing that should be mentioned is that the original files (mxf) and the QT import should not be kept on the same drive.
Chris Baldwin
Re: CONTENTS
on Apr 17, 2008 at 4:43:48 pm
Is this simply because you're trying to safe gaurd against data loss or because having the P2 volumes and the QT clips on the same drive is somehow dangerous to the clips?
thanks
