Math: Add beveled corners to polygon script
COW Forums : Adobe Flash
Jakob Wagner
on Mar 26, 2017 at 11:57:46 am
Hi
I have this script which can position a number of objects in a polygon or star shape. Great!
The only problem is I would like to be able to bevel the corners, or to say it in another way, create some roundness on them.
Can anybody here figure out the math in that?
Let me know if I need to explain more.
Jakob
The script:
package
import flash.display.MovieClip;
import flash.display.Graphics;
import flash.display.Sprite;
import flash.geom.Point;
import flash.events.Event;
public class Polygon extends MovieClip
private var numberOfMarkers;
private var markers:Sprite;
private var offset:Number;
private var numberOfSides:int;
private var polygonAngle:Number;
public function Polygon()
numberOfMarkers = 50;
offset = 0;
numberOfSides = 5;
polygonAngle = 90;
markers = new Sprite();
addChild(markers);
for(var i:int=0;i 2)
var points:Array = [];
var step:Number, halfStep:Number, start:Number, n:Number, dx:Number, dy:Number;
step = (Math.PI * 2) / spikes;
halfStep = step / 2;
start = (angle / 180) * Math.PI;
points[0] = new Point(x + (Math.cos(start) * outerRadius), y - (Math.sin(start) * outerRadius));
for (var i:int=1;i<=spikes;++i)
dx = x + Math.cos(start + (step * i) - halfStep) * innerRadius;
dy = y - Math.sin(start + (step * i) - halfStep) * innerRadius;
points[(i-1)*2+1] = new Point(dx, dy);
dx = x + Math.cos(start + (step * i)) * outerRadius;
dy = y - Math.sin(start + (step * i)) * outerRadius;
points[(i-1)*2+2] = new Point(dx, dy);
atAngle = atAngle%360;
var sideLength:Number = Point.distance(points[0], points[1]);
var totalLength:Number = sideLength*spikes*2;
var distanceFromStart:Number = totalLength*atAngle/360;
var startPoint:int = Math.floor(distanceFromStart/sideLength);
var endPoint:int = startPoint==spikes*2-1?0:startPoint+1;
var distanceFromStartPoint:Number = distanceFromStart-(sideLength*startPoint);
var a:Number = points[startPoint].x-points[endPoint].x;
var b:Number = points[startPoint].y-points[endPoint].y;
var A:Number = Math.atan(a/b);
var na:Number = Math.sin(A)*distanceFromStartPoint*(b<0?1:-1);
var nb:Number = Math.cos(A)*distanceFromStartPoint*(b<0?1:-1);
target.x = points[startPoint].x+na;
target.y = points[startPoint].y+nb;
target.rotation = 90-A/(Math.PI/180);
public function positionInPolygon(target:Sprite, x:Number, y:Number, sides:uint, radius:Number, angle:Number, atAngle:Number):void
if (sides <= 2)
throw ArgumentError("DrawingShapes.drawPolygon() - parameter 'sides' needs to be atleast 3");
return;
if (sides > 2)
var step:Number, start:Number, dx:Number, dy:Number;
step = (Math.PI * 2) / sides;
points[0] = new Point(x + (Math.cos(start) * radius), y - (Math.sin(start) * radius));
for (var i:int=1;i<=sides;++i)
dx = x + Math.cos(start + (step * i)) * radius;
dy = y - Math.sin(start + (step * i)) * radius;
points[i] = new Point(dx, dy);
var sideLength:Number = 2*radius*Math.sin(Math.PI/sides);
var totalLength:Number = sideLength*sides;
var endPoint:int = startPoint==sides-1?0:startPoint+1;
