Go to the frame of sequence (system time(clock)
COW Forums : Adobe Flash
Maxim Ilin
on Sep 2, 2015 at 11:02:27 am
Prompt please- I'll 3Dshnik only started as a Flash with ActionScript 3 solve this problem! There sikventsy cubes rendered in Maya! It is necessary to sequence loaded (desired frames) depending on the time of the system (that is, make the clock as a result of such a plan! I I understand for the second cube has 1500 frames - you need to be synchronized with the computer time ie how to write the script as I understand it to go to the respective second frames (there are 25)! Well, mathematically, I hit upon the idea-although the code is used to write and nothing poluchaetsya (((
© 2018 All Rights Reserved
