web animation not running on page load
COW Forums : Adobe Flash
thierry eymard
on Dec 11, 2014 at 11:03:02 pm
i have created a createjs file(html) that i can place on a wordpress page which runs after you click on it on a new page,how can i make it run on the main page on startup of mainpage being loaded.Is this a script issue,function-onload?
I have also tried using an animated giff for this animation that runs fine on startup but the createjs one does not...any ideas
Sam Mattern
Re: web animation not running on page load
on Dec 21, 2014 at 4:00:25 pm
Have you tried copying the content of the createjs into the body of the main page?
thierry eymard
on Dec 28, 2014 at 7:17:58 am
there are 2 folders,,,images and libs,then 2 files,,bikejs.html and bike js.js
if i insert the html file in the page it only gives me a background color of the animation only,i tried to put all the files in a page but only seems to display each file in a text editor...i tried using a html plugin (HTML Javascript Adder) but i think its only for a side bar ,and could not work out how to run it...
should not the .html file find all the necessary files in the media library.
should there be a link of some sort in the header?
just guessing...thx for any help..
i have an animated giff running instead which does the job but thought this .html way was the latest trend these days for animation...
© 2018 All Rights Reserved
