Exported SWF file always the same size, even when dimensions changed?
COW Forums : Adobe Flash
guy ward
on Dec 9, 2014 at 11:09:37 am
hello everyone, I have had a good look around for the answer, but here's my problem:
1. I export a 25 second flash banner (970x250)
2. It's 1.8mb
3. If I change the banner to about half size (450x150) its still 1.8mb
4. In 'Publish Settings' changing the Jpeg quality (1-100) also makes no difference.
I don't understand why the size is staying the same?
The pictures I used to make the swf are 301kb, so I don't think the size is coming from them.
I'm very new to Flash, any help greatly appreciated!
Sam Mattern
Re: Exported SWF file always the same size, even when dimensions changed?
on Dec 10, 2014 at 2:10:37 pm
Did you change the dimensions of the contents or change the size of the stage? Or both?
-Sam
guy ward
on Dec 12, 2014 at 12:19:27 pm
hi, thanks for replying, so the stage is a set size of 970x250, the contents is a photo that is about 3x as big - because it pans over it so needs to be that big - but the file is only 90kb
