How do I resize images in different frames to a certain size?
COW Forums : Adobe Flash
Jana Narin
on May 21, 2014 at 2:28:29 pm
I have about 20 frames in a single layer (and a single, long frame in another layer -- this functions as the background layer). Each frame contains a different image. But each image is set to the document size of 700 px by 400 px. I would like to change all of the image sizes to 1920 px by 1080 px.
Is there a quicker way to do that besides having to click on the images in each frame, going to the properties panel, and manually changing the width and the height from there? Thanks to anyone who would be of help.
Sam Mattern
Re: How do I resize images in different frames to a certain size?
on Jun 20, 2014 at 1:00:53 pm
What are the original size of the images? Best practice would be importing the images already at 1920 x 1080.
I would do a batch in Photoshop (if you have it) to resize them all. Then they will import correctly. I'm sure you can find a freeware batch image resizer to do it for you if you don't have Photoshop. Maybe try http://www.fotosizer.com/
Otherwise you'd have to do it programmatically and at that point it'd be faster to manually resize them all.
-Sam
