fl.xmlui javascript what is going on, how does it work
COW Forums : Adobe Flash
martin minsel
on May 7, 2014 at 8:55:45 am
I created a javascript which loads up an UI in Flash. I would like to make a dropdown menu or a list, with a variable set of members. The items this dropdown list should depend on the selection made in another dropdown list.
I can call functions in the ui on create and when the focus was changed, but I cannot edit the control elements in the ui because I can't get the fl.xmlui.getControlElement method to work as described in the API:
To reproduce this I created the following XML exampleUI.xml:
and the following javascript exampleJS.jsfl:
var xmlUi = fl.getDocumentDOM().xmlPanel(fl.scriptURI + "/../exampleUI.xml");
If I execute exampleJS
the ui is started and the callback oncreate of the menulist is launched. This is the output of the fillList() function:
menuItem0 label = value =
testList label = value =
testLabel label = value =
testLabel = John menuItem0 = undefined testList =
I would have expected something like this:
menuItem0 label = herp value = derp
testList label = bla value = derp//currently selected item
testLabel label = testLabel value = John
testLabel = John menuItem0 = derp testList = derp/*currently selected item*/
I have no idea what I'm doing wrong. I would be very grateful for any kind of clue.
© 2018 All Rights Reserved
