Adobe Flash is not working in Adobe Acrobat Reader
COW Forums : Adobe Flash
Andrew Weyrich
on Apr 2, 2013 at 6:30:14 pm
Hi - I created a bunch of Flash tabs in Flash CS6 - they work great - but I want to put them into Adobe Acrobat X PRO (the writer) and they imported just fine and work just great inside of Acrobat X PRO. However when I go to send the exported PDF with the Flash elements inside of it - to someone who only has Acrobat Reader (but doesn't have the Flash plug-in installed on their machine) - that person can open the PDF and can even view the Flash element but they get a yellow bar across the top of the PDF that says they must install the Flash plug-in to use it. Well that is great but this PDF is being used out in the field where they cannot install the Flash plugin....
I am suprised it does this because Flash importing and exporting capability is native to Acrobat Reader...and I thought I read that Acrobat has flash reading/rendering capability natively built into the Reader itself. Am I wrong - and/or does anyone have a workaround for this??
© 2018 All Rights Reserved
