Sintax error
COW Forums : Adobe Flash
Abigail perez
Sintax error
on Mar 2, 2013 at 6:07:14 pm
i'm making a project and it doesn't work, i tried fixing the errors but it still won't work.. i have this code
Stop()
Circ1.addEventListener (Mouse.CLICK, ircircle);
function ircircle(Event:MouseEvent) {
gotoAndStop(5);
Cuad1.addEventListener (Mouse.CLICK, ircuadrado);
function ircuadrado(Event:MouseEvent) {
gotoAndStop(10);
Rec1.addEventListener (Mouse.CLICK, irrectangulo);
function irrectangulo(Event:MouseEvent) {
gotoAndStop(15);
Tri1.addEventListener (Mouse.CLICK, irtriangulo);
function irtiangulo(Event:MouseEvent) {
gotoAndStop(20);
Is.addEventListener (Mouse.CLICK, irisosceles);
function irisosceles(Event:MouseEvent){
gotoAndStop(25);
Eq.addEventListener (Mouse.CLICK, irequilatero);
function irequilatero(Event:MouseEvent) {
gotoAndStop(30);
Es.addEventListener (Mouse.CLICK, irescaleno);
function irescaleno(Event:MouseEvent) {
gotoAndStop(35);
demetri tashie
Re: Sintax error
on Mar 3, 2013 at 2:07:13 am
your event listener in this/these case(s) should be 'MouseEvent', not just 'Mouse' as you have it written.
change them all and see if that works for you
for example:
Circ1.addEventListener (<b>MouseEvent</b>.CLICK, ircircle);
and as best practice the functions should have a return type specified, which in this case is 'void'
example:
function ircircle(Event:MouseEvent<b>):void</b> {
Abigail perez
Re: Sintax error
on Mar 3, 2013 at 5:34:40 pm
it worked! thank you so much!
