White flash frame when moving between levels.
COW Forums : Adobe Flash
elliott linehan-cross
on Jan 13, 2013 at 12:30:23 pm
HI all,
This is my first post in the forum so i would like to say hi and thank you in-advance for any help!
I am building a basic application with in Flash, witch it draws video files in and moves about different 'levels' with in the application.
The problem i am having is that;
The first page is on level '0'. you then move to the next area on level '1' draw a video in (on press of a button) this load on level '2', then to close the video, on press again, the area should load on level '0', this all works fine, but on the close of the video and the old area being placed, there is a white full screen flash, like some thing is refreshing.
I managed to get rid of this but then i encountered different problem, such as the video not actually closing or the layer underneath changing to the wrong one.
I dont know if this will make much sense when reading it. I am quite new to using flash but am having alot of problems with this,
Elliott
