Button Rollover with seperate movie-clip animation
COW Forums : Adobe Flash
Philip Hogarth
on Oct 26, 2012 at 3:53:42 pm
I have decided to improve a project as I am pursuing web developer positions and the design fizzled out after the first page, and should have included more tweens. I have a monkey with a large leaf, please see attached, and I want the monkey to point to the desired button on rollover and to retract when on rollout or when clicked. I have some basic script in at the moment which affects the Flunkey movie clip which consists of an armature layer spread over 15 frames with an actionscript layer consisting of 4 stop() actions at frame 1, 5, 10 and 15, or, starting position, top-button, middle-button and bottom-button. This just affects the top button at the moment. The case statements do need correctly ordering but I will do this later.
Can you help me please.
Phil.
AS.
import com.greensock.*;
import com.greensock.easing.*;
var numberOfButtons:Number = 3
var startX:Number;
var startY:Number;
var currentButton:MovieClip
for (var i:int = 1; i <= numberOfButtons; i++)
this["btn"+i].buttonMode = true;
this["btn"+i].mouseChildren = false;
this["btn"+i].addEventListener(MouseEvent.MOUSE_OVER, doRollover)
this["btn"+i].addEventListener(MouseEvent.MOUSE_OUT, doRollout)
this["btn"+i].addEventListener(MouseEvent.CLICK, showContent);
function doRollover(e:MouseEvent):void
TweenMax.to(this[e.target.name], 1, {scaleX:1.1, scaleY:1.1, ease:Elastic.easeOut});
mcFlunkey.gotoAndPlay(5);
// This function handles the Rollout event
function doRollout(e:MouseEvent):void
TweenMax.to(this[e.target.name], 1, {scaleX:1, scaleY:1, ease:Elastic.easeOut});
mcFlunkey.gotoAndStop(1);
function showContent(e:MouseEvent):void
currentButton = this[e.target.name]
switch (currentButton)
case btn1:
TweenMax.from(mcGallery, 1, {x:450, y:300, scaleX:1, scaleY:1, ease:Back.easeOut});
mcGallery.gotoAndStop(2);
mcGallery.parent.setChildIndex(mcGallery, mcGallery.parent.numChildren-1);
break;
case btn2:
TweenMax.from(flvPlayer, 1, {x:-72, y:-721, ease:Back.easeOut});
flvPlayer.gotoAndStop(2);
flvPlayer.parent.setChildIndex(flvPlayer, flvPlayer.parent.numChildren-1);
break;
case btn3:
audioPlayer.gotoAndStop(2);
break;
