Using flash to create interactive video
COW Forums : Adobe Flash
Liz Jamar
on Oct 24, 2012 at 6:59:15 pm
Hi all,
I am sure this has been covered somewhere on the WWW, but the company I work for is looking to create interactive training videos and we have turned to flash.
I am really new to Flash and was wondering is anyone out there had some tutorial links. I have tried google search but keep coming back with no good results.
Thank you.
-Liz
So new to flash, oh so new.
Sam Mattern
Re: Using flash to create interactive video
on Oct 25, 2012 at 12:23:01 pm
I find flash tutorials are more receptive to a specific search term, such as "flash button tutorial." There are a lot of great sites with tutorials, starting with our very own Creative Cow.
http://library.creativecow.net/video-tutorials/adobeflash
Also, Kirupa.com, Flashkit.com, and the inbuilt tutorials in the Flash program itself.
Another thing that can help is replacing "flash" with "as3" or "as2" when searching. Since the programming language in Flash is Actionscript (Actionscript3 is the current iteration, AS2 is used for Flash Professional 8 and below), you can search "as3 button tutorial" if you specifically need help with the coding part.
-Sam
demetri tashie
on Oct 25, 2012 at 3:04:58 pm
most interactive videos using flash, will either be one long video which employs embedded cuepoints, or else the video will be broken up into its relevant sections
bare-bones workflow for cuepoints:
event cuepoints are embedded where you want something to happen - the video stops, buttons appear, or othere means of interactivity becomes possible when the video player hears that event cue point be reached. the buttons/interactivity is coded for your choices. based on that, it would either continue play or jump to another section via emebedded navigation cue points.
or:
the video is broken up into sepearate videos for each section. at the end of each section ( on reaching completion of that video) buttons or other things appear to allow for the interactivity/choices to be made. depending on the answer/request, the next relevant video is loaded and the tutorial proceeds.
as sam says, there are many tutorials out there, but it is best to search more specifically: as3 cuepoints, etc
and of course, feel free to ask us more specific questions too!
