F4V Movies have black transitions
COW Forums : Adobe Flash
Jacqueline Johnsen
on Oct 13, 2012 at 3:27:27 pm
I have imported f4v movies into my flashfile and they all work perfectly but there is a second at the start of each movie (I think it needs to load) where there appears a black screen for a second. I tried to add a template image to the f4v but that either didn't work or I failed to do so.
The fl4 are imported with: load external video with playback component.
Can someone plx tell me if the template (or background) image with the video works or if I have to start embedding the files?
Extra info: I also tried to add an image above the first few frames of each movie but it doesn't seem to start loading unless it's visible?
Thanks and take care.
Jacqueline Johnsen
Re: F4V Movies have black transitions
on Oct 14, 2012 at 5:42:40 pm
Ah, correction: Putting an image above the f4v in flash does work, it just takes up a lot of frames before it covers the black transition. *sigh* it's not ideal because it still looks like it hesitates before playing the movie. Solution anyone?
© 2018 All Rights Reserved
