Cue points Paramters Output into Flash
COW Forums : Adobe Flash
Steven Stanczak
on Jun 18, 2012 at 8:22:18 am
Hey,
I've been busy with a link between after effect en flash. I've seen a method of exporting a movie (flv) with cue points that contains parameters such as:
- Position
- Rotation
- Corner pins
- Blur etc
What I did till now:
1) Simply tacked a movie and applied the data to a corner pin. So the recorded data are: Object Position and Corner Pin Positions (top left and right, bottom left and right.
2)The I converted all data to Markers by selecting all data and by using the script: Convert Selected Properties to Markers.
3)Renderd the Composition out to a .flv.
4)Imported the flv into flash and add a piece of code to read the cuepoints:
import fl.video.MetadataEvent;
my_FLVPlybk.addEventListener(MetadataEvent.CUE_POINT, fl_CuePointHandler);
function fl_CuePointHandler(event:MetadataEvent):void
trace("Elapsed time in seconds: " + my_FLVPlybk.playheadTime);
trace("Cue point name is: " + event.info.name);
trace("Cue point type is: " + event.info.type);
trace("Cue point value is: " + event.info.value);
stop();
Now here comes the problem. The code works and I'm able to read the cuepoints:
- Name
- Time
- and Type
But I'm unable to output the Parameters information & Value of the corner pins.
I've tried several options to output the Transform_Position parameter but I end up getting:
Elapsed time in seconds: 0
Cue point name is: 0
Cue point type is: event
Cue point value is: undefined
My goal is to output this information and link that information to a object.
Hope I explained it well and that there's someone able to help me out.
Greets,
Steven
Steven Stanczak
Re: Cue points Paramters Output into Flash
on Jun 18, 2012 at 9:11:17 am
And if I use:
trace("Cue point value is: " + event.info.parameters);
I get:
Elapsed time in seconds: 6.64
Cue point name is: 6.64
Cue point value is:
