How do i make an interactive 3d object rotate with mouse drag?
COW Forums : Adobe Flash
catherine sulzmann
on Apr 30, 2012 at 1:22:17 pm
Hello!
I want to almost recreate the link I have attached below.
http://bmc.erin.utoronto.ca/~enid/interactivethyroidectomy/
Basically I have rendered jpeg images from Maya or a movie clip of some shoulder bones rotating around 360 degrees. And I want to make an interactive 3d flash file so that users can rotate around the object just by using their mouse to move only right and left. I don't need to it rotate superiorly or inferiorly over the object, and I don't need to be able to scale it.
I've been searching for days for a good tutorial but most websites just give a list of code that I find hard to interpret.
Could some one kindly help me with this?
I'm working in AS2 at the moment
Thank you in advance
Catherine
catherine sulzmann
Re: How do i make an interactive 3d object rotate with mouse drag?
on May 20, 2012 at 3:52:34 pm
Hi could any one help me with this project?
There is another example below of what I mean - but I'd rather learn how to do it myself than buying the code on this website. Could someone point me in the direction of a tutorial?
http://activeden.net/item/interactive-renders-360-deg-3d-object-rotator/397...
Thanks again
Catherine
catherine sulzmann
on Jun 14, 2012 at 1:26:31 pm
Just in case anyone also comes across this problem,
I found an entire post about it, including all the coding at:
http://forums.adobe.com/message/851798#851798
acif raja
on Feb 11, 2013 at 11:27:10 am
Thats great, many thanks for finding some resources for this. did you mange to get the effect you wanted?
Rohit Rajan
on Sep 3, 2013 at 12:41:39 pm
Thats very helpfull catherine.really appreaciate that.It helped me a lot.
